Tv Reception.
Tv antennas receive the best when nothing is crowding in to reduce or block reception.
Trees and tree leaves are very good at reducing or blocking reception.
Buildings in the way of reception will reduce and block reception.
Aiming the antenna in to the roof of your house will reduce or block reception.
Mount the antenna in such a manner that there is the least amount of objects that will reduce or block reception.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
________________________________________________________
The Pomeranian that lives with me likes to swim in the lake.
