Old 16-Sep-2010, 1:07 AM   #7
Dave Loudin
Before we're finished, you need to rerun your report and vary the antenna height at the point where you can drag the receive marker on the map. Every time you click away from the box, the predictions update. What you're looking for is a big increase in the NMs of the Pittsburgh and Akron/Cleveland stations.
Based on your current data, I'd recommend a Winegard HD7698P aimed at Pittsburgh. If you don't care about WPCW (CW) and WQED (PBS), you can use an Antennas Direct XG-91 aimed at Pittsburgh. Either way, the locals are strong enough to come in off-axis.
IF, and ONLY if the NMs improve to at least near zero for the Akron/Cleveland stations, I would use a rotator with the Winegard antenna.
Good luck!
