Thread: Cancelled Dish!
Old 23-Jul-2012, 10:04 PM   #16
bluefull
To focus on Teleview's question, only one balun (matching transformer) should be connected to the antenna terminals.
To feed three separate households you should use a balanced 3-way splitter if the cable runs are roughly equal in length. If one of the cable runs is significantly longer, use a typical 3-way splitter which has low loss on one of the three ports, which would be used to feed the longest coax run.
Ah, so only one balun should be connected to the antenna. How far from the balun can or should the splitter be? How to waterproof the coax connections? I know for the balun there are weather boots/sleeves.
The cable runs are on three separate floors so my run would probably be the longest (1st floor of a 3-story building). I would connect my coax to the 'power pass' port then.
I was considering just buying a separate, smaller antenna just for myself and attach it to the same mast but just underneath the larger antenna. Specifically the Winegard HD7694P that teleview mentioned.
bluefull is offline   Reply With Quote
