Tv Reception.
Attics are not the best place to have a antenna.
Metal roofs will reduce and block reception.
Thick roof tiles will reduce and block reception.
Solar panles will reduce and block reception.
Metal backed insulation will reduce and block reception.
Stucko Wire on outside walls that are as high as the attic will reduce or block reception.
Metal duct work in the attic will reduce or block reception.
Heating and air conditioning units that are in the attic will reduce or block reception.
