Old 23-Jul-2012, 4:28 PM   #3
Tv Reception.
To receive more Tv stations/channels then your neighbor , with a antenna installed in the attic.
Install a , Clear Stream 2 Complete UHF/VHF antenna. http://www.antennasdirect.com/store/...VHF-Combo.html.
Also use a Channel Master CM3414 distribution amplifier to distribute the Tv signals out to the Tv's
Take note that this is not the Plain Jane UHF CS2 antenna.
This is the CS2 Complete UHF/VHF antenna.
The CS2 Complete UHF/VHF antenna receives VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Your location has Tv transmitters that are transmitting VHF high band channels in the 7 thru 13 , and UHF band channels in the 14 thru 51.
Remove the Reflector Screen from the CS2 Complete UHF/VHF antenna and mount CS2 Complete UHF/VHF antenna in the attic.
With the Reflector Screen removed the CS2 Complete UHF/VHF will receive Tv stations/channels at the front and back of the antenna.
Aim the CS2 Complete UHF/VHF antenna with the reflector screen removed at about 340 degree magnetic compass.
So with one side aimed at about 340 degree that means that the other side is aimed at about 160 degree magnetic compass.
Because your location has Tv stations/channels to the , north west , north , north east and south east.
The SC2 Complete UHF/VHF antenna with the reflector screen removed is now receiving Tv stations/channels to the , north west , north , north east and south east.
At the front and back of the CS2 Complete UHF/VHF antenna.
Here are places to buy Tv antennas and etc. , http://www.solidsignal.com ,http://www.antennasdirect.com , http://www.channelmasterstore.com , http://www.amazon.com.
