Old 23-Jul-2012, 2:43 AM   #15
Though it's not exact by any means, a zip code level report at 40' vs. 25' shows a significant improvement in signal levels. Enough to have confidence that the HD7698P would provide both UHF and High-VHF reception from the Chicago direction.
A push-up mast may be a good option for you. Though I doubt you would use it day to day, a rotator may be worth the expense... with the antenna out of reach, fine tuning the aim would be much easier with a rotator.
http://www.3starinc.com/telescoping_masts.html
http://www.3starinc.com/antenna_rotors.html
