Old 22-Jul-2012, 11:34 PM   #6
geo
If you need to get the cable through the roof then instead of the J-pole, a section of rigid 1 1/4" electrical conduit topped with a weather-head, sealed at the roof deck with a conventional roof flashing can serve very well as an antenna mast, provided the mast is secure, so it can't move in the wind causing the flashing (boot) to leak over time.
Thanks that is pretty much what I was thinking. We have been without cable for over two years and I do not miss the bill one bit.
I need help with getting the mast properly grounded. Our house is old and there is no grounding rod. There is a ground wire from the breaker box fished through the attic and back down to the water line inside the house. Single story on a slab.
I don't have a problem installing a grounding rod for the antenna mast but I am not clear on how to bond it, should it tie into the service panel? I want to make sure everything is done correctly.
geo is offline   Reply With Quote
