DTV/cell phone reception advise and products
Your reception is a little too weak for good results with an indoor antenna.
I recommend you try a Terk HDTVo. You can mount this antenna on your roof or and surface such as a deck post, as long as it faces the North. Aim due South and you will receive the NBC station and more. Another slightly larger antenna to look at is the RCA ANT 751. A better choice if you have the space to mount it, also pointed North.
