Tv Reception.
How many Tv's did you say are/will be connected??
The HD7000R antenna is not a very directional antenna , the antenna does receive the best at the front of the antenna , however will also receive at angles to the Tv antenna.
With the HD7000R aimed at about 310 degree magnetic compass that will put WLIW-DT 21 PBS , at about 89 degree magnetic compass , reception angle to the HD7000R.
I am thinking that WLIW will be received Ok.
