Tv Reception.
The HD7084P antenna is large directional antenna that will do a better job of rejecting interfering signals from other directions then the HD7696P antenna.
The HD7084P antenna is a All Channel antenna , channels 2 thru 51.
All the Tv channels are.
UHF band channels 14 thru 51.
The receivable channels at this location are in All 3 Tv bands.
Here are Examples , but not the only examples.
WPVI-DT - VHF low band Real channel 6 , Virtual channel (6.1) ABC.
WBPH-TV - VHF high band Real channel 9 , Virtual channel (60.1) IND.
KYW-TV - UHF band Real channel 26 , Virtual channel (3.1) CBS.
The HD7696P is designed to receive , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
And the HD7696P antenna does not do as good of job rejecting interfering signals from other directions as the HD7084P antenna.
