Old 22-Jul-2012, 3:48 AM   #7
Thanks for posting the TVFR link.
That appears to be a Winegard HD7082P. It appears to be intact, with only a small amount of sagging or bending of a few elements. If there are no other problems with it, it should be more than enogh antenna for the Milwaukee signals. Aimed at about 20° compass, you can remove the preamp and expect to have plenty of signal to drive a passive 4 or 8-way splitter. If you are going to connect three sets, use a 3-way splitter.
http://www.winegarddirect.com/pdf/spec_HD7080P.pdf
Actually, rather than saying 'can remove' I am inclined toward saying 'you really ought to remove the preamp'. You have so much signal power to work with, many preamps would overload, leaving with lower quality signal.
Last edited by GroundUrMast; 22-Jul-2012 at 3:54 AM. Reason: added link to HD7082P specs
