Old 21-Jul-2012, 8:47 PM   #8
Tv Reception.
I see that your location has receivable Tv stations/channels in the , VHF band channels 7 thru 13 and UHF band channels 14 thru 51.
I see that a HD7696P antenna is recommended that receives channels 7 thru 51.
And the recommend aim direction is 160 degree magnetic compass.
I see that you installed a CS4 , UHF channels 14 thru 51 , antenna.
I see that there is Metal backed insulation in the attic on the underside of the roof , this puts the metal backed insulation in the way of reception.
Reception will be improved by mounting the HD7696P antenna Above the roof in such a manner the HD7696P antenna is Above the roof so that the roof is not blocking reception.
Here are some Above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/3442560.html , http://www.ronard.com/ychim.html.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always the starting antenna aim direction is the --> starting aim direction.
The antenna is then turned to find the direction that produces the best reception.
