After reading a few other post I will add that my house is wood frame construction and asphalt shingles. I do have this insulating board that is install that has a shiny foil like backing. I don't remember the name. Ill have to go look
Finally got around to installing antenna in attic. Trying a CS4 but I am having significant artifacts on WAPT UHF 21...
Foil faced insulation will cause quite a bit of signal reflection. Is the insulating board on the underside of the roof deck or on the attic floor?
Have you tried various locations in the attic? Have you experimented with aim?
How is reception of WJTV, real CH-12?
