Old 21-Jul-2012, 1:08 PM   #4
hdtvfan44
Thank you for the response so far. I have some work ahead. I currently have an antenna that is pointed to the Milwaukee Towers (it is hooked up but doesn't work the best). I think I need to get someone in to remove the pre-amp and get a new coax cable running down. While my indoor rabbit ears work well for the most part, they don't always work that well)
I may need a new antenna altogether. I was thinking of possibly two, one pointing towards Chicago and one towards Milwaukee, using an AB switch for one TV in the meantime.
To answer that question though, I think 3 or 4 TVs to eventually be connected. I'm assuming the Milwaukee antenna will not need a pre amp or an amp, but if I really want to try for Chicago I'll need a good amp.
hdtvfan44 is offline   Reply With Quote
