Thread: Condo Solution
Old 21-Jul-2012, 9:36 AM   #15
wwfjdraw
Originally Posted by teleview View Post
Your location has receivable VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
The ANT751 is designed to receive Tv channels 7 thru 51 the best.
The DB4e is designed to receive the UHF band channels 14 thru 51 the best.
If you will like to use a 100% Honest antenna for your location , it has more receiving elements , and as such will receive better and is designed to receive channels 7 thru 51 , then use a Winegard HD7694P antenna.
OK so I get what your saying. My goal is channels 7-13 on one frequency and 14-51 on another.
And your saying that the DB4E only receives UHF which limits me to channels 14-51 so the DB4E is not in consideration anymore.
But the RCA one gets both 7-13 and 14-51 because you said that it gets 7-51.
But your also saying that the WineGard gets everything the RCA does but has better elements so the WineGard is the better one. And the WineGard is the best.
Does the WineGard have to install any more difficultly? Or can I just ducttape this to the railing outside aswell?
wwfjdraw is offline   Reply With Quote
