Thread: Condo Solution
Old 21-Jul-2012, 6:29 AM   #13
Tv Reception.
I recommend the ANT751 antenna , a 100% Honest antenna.
The issue is the size of the antenna verses the size of the space to install a antenna at apartments.
Your location has receivable VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
The ANT751 is designed to receive Tv channels 7 thru 51 the best.
The DB4e is designed to receive the UHF band channels 14 thru 51 the best.
Money will not buy ones way into Tv reception. Be it 100% Honest information or straight out Lies.
There are many people selling scam Tv antennas now days , they say that this amount of money or that amount of money will get you 150 mile Tv reception with the 'Magic' Tv antenna , it is straight out Lies.
If you will like to use a 100% Honest antenna for your location , it has more receiving elements , and as such will receive better and is designed to receive channels 7 thru 51 , then use a Winegard HD7694P antenna.
http://www.winegarddirect.com , http://www.solidsignal.com.
