I should add. I swapped out my RG6 for RG11 (100 foot run) and even though I am using a Pre amp (8275 from Winegard) I saw a 1.5 to 2 db gain across all channels. Whoever claims you don't need both for improving the strength of a weak signal is uninformed. It worked for me. If you see some signals breaking up after you install your new antenna or antennas and believe that another db or two will stabilize the picture, then I recommend trying RG 11 in place of RG 6 cable.
