I would personally use a pre-amp like the Winegard 2870 with separate inputs instead of using a combiner. You will never get back the 1/2 to 1 db gain lost with a UVSJ antenna combiner. Not sure if the low noise figure of the Kitztech amp will make much difference at the end of the day, so maybe others can comment.
