I think you would do well with a Winegard HD7695P and a rotator.
Any time you try to connect two antennas together, you reduce their effective gain, so it's not so good at picking up the stations further away.
If you go with a single antenna on a rotator, you will probably also have access to channels from other directions, like KFFX to the east.
If you want to pull in stations even further down into the "red" zone on your list, you can probably do so by going with a larger version of the antenna (like the HD7698P) and adding a mast-mounted pre-amp like the Winegard AP-8700.
