Tv Reception.
Teleview provided a direct link to the CS2 Complete UHF/VHF antenna.
Teleview provide the information about the Tv stations/channels in different directions and the antenna to receive them.
Your location has receivable Tv stations/channels in the VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
In the tvfool channel list are the REAL channels that are transmitted and received , and the Virtual channels.
The Virtual channels in most cases is the Analog Tv channel that the Tv station was transmitting on before the change to digital , many Tv stations kept the Old Analog Number even though the Tv station may or may not be transmitting the old channel.
AS an example and not the only example , WLTW NBC was transmitting Analog on channel 5 , during the change to digital WLTW NBC is now transmitting on UHF channel 35 and the transmission is digital.
There is No WLTW NBC analog channel 5 , the 5 is now a Virtual channel.
More examples.
WKRC-DT Real VHF high band channel 12 is what is transmitted and received , Virtual channel (12.1) is a Virtual channel.
WLJC-TV Real VHF high band channel 7 is what is transmitted and received , Virtual channel (65.1) is a virtual channel.
The HD7084P is a directional All channel antenna that is not the best choice for your location that has receivable Tv stations channels in 2 directions.
The CM4228 is a UHF antenna channels 14 thru 51 that has a , rod type reflector screen , that Is Not easley removed for reception in 2 directions and once removed is not easley put back on.
