Old 20-Jul-2012, 2:52 AM   #4
Dea
Hi,
thank you both for your advises.
GroundUrMast,
One of my TV is flat - Toshiba 32" 720p 60Hz LCD HDTV (32C120U). I just connected the antenna to the TV. There is no option to set it to scan for "Antenna" or "Air" channels. Just scanning.
The other TV is tube - Citezen. I read in the forum that if I want to connect it to the same antenna between the TV and the coax cable I have to use converter. I don't know which model will be better to buy. Before your question I even didn't know that there are different converters.
Dea is offline   Reply With Quote
