If you have no options for outside mounting, you can still hope to see some channels. Your success depends on whether you have a clear view toward Mt. Wilson. If you can aim the HDTVi or HDTVa through a window, you can hope for some reception.
You can also consider using an outdoor antenna such as one of the Clear Stream series from Antennas Direct. The larger CS-4 would have more gain than the smaller versions. The CS-1, CS-2 and CS-4 are all UHF only designs but a VHF add on kit is also available.
The RCA ANT-751 also comes to mind when thinking of people trapped in an apartment or condo.
