Old 20-Jul-2012, 1:02 AM   #2
In an attempt to keep things organized, I've separated your thread.
Re. your questions; Neither antenna is ideal for your application. The signal conditions are such that reliable reception will require an antenna with more gain, mounted outside clear of obstructions.
I would suggest a Winegard HD7698P equipped with an Antennas Direct PA-18 preamplifier. Both are available from the manufactures web sites and online retailers such as Amazon, SolidSignal, 3starinc and others. Those retailers will also offer a variety of mounting hardware and related supplies.
There is one signal on real CH-2 that might be receivable, though with little margin for signal fading. The pending report indicates the possibility of a station to be built on CH-3 but also weak enough to be marginal. If you want to try to receive either of these, you would need to consider using a Winegard HD8200U which is the largest antenna offered by Winegard.
