Old 19-Jul-2012, 11:33 PM   #8
Tv Reception.
Check the antenna , see if the antenna matching transformer (balun) is making the connection to the antenna wires inside the plastic housing.
A way to test reception is to bypass all coax.
Install a Known to be good looong coax connected directly to the antenna and run the coax through a open window or open door directly to the Tv.
Here are some above roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegard.com , http://www.amazon.com.
Also install a Winegard AP8700 preamp.
