Old 19-Jul-2012, 11:21 PM   #7
Tv Reception.
Aim the HD7694P antenna at about 335 degree magnetic compass.
For now have only the one Tv connected.
The coax that is being used to get the signal from the antenna to the Tv can not have any of the satellite Tv or cable Tv hardware , diplexers , splitters , ect. connected.
Just the coax only to get the signal from the antenna to the Tv.
The Tv Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Tv's will automatic channel scan for cable tv channels if the automatic mode is selected.
