Tv Reception.
So that leaves KOLN-DT channel 10 , CBS and MyNetwork. at 91 degree magnetic compass. Signal strength 28.7 NM (dB) , plenty strong.
And KGIN-DT channel 11 , CBS and MyNetwork. at 241 degree magnetic compass. Signal Strength 12.7 NM(dB) , weak but receivable.
The C5 does a fairly good job of receiving in all directions.
Best reception at the front and good reception at back of the antenna and less at the sides of the C5 antenna.
Turn the C5 antenna to the left and right to find a antenna position that receives one or both.
Either one or both should be easy to receive.
A preamplifier can be installed , a Antennas Direct CPA-19.
The antennas are connected to the combiner and the CPA-19 preamp is connected the combiner so that both antennas have the Tv signals pushed through the coax out to the Tv.
