Old 19-Jul-2012, 9:16 PM   #41
energyzer
Do you have a preamp connected? If so, what make/model?
What's the total length of coax from the antenna to the tuner?
Can you describe the layout from the antenna to the tuner?
(Ex. Antenna, 2 feet of RG-6, UVSJ combiner, 10 feet of RG-6, splice, 50 feet of RG-6, 8-way splitter, 15 feet of RG-6, tuner)
No preamp, due to me only having one tv hooked up. I estimate that I have about 130' of RG-6. (it is the exact same cable that was used with my DirectV set up. It would be a few feet between the antenna and the long cable run, joined by a barrel connector. Next run would be aproximatly 91 feet, then barrel connector for another 25 feet, where it runs into the house, so there would be another barrel connector, then the remainder to the tv. (all measurments are approximate).
Channels I'm pulling:
KHAS-DT 5.1
KHAS-D2 5.2
KLKN-TV 8.1
KLKN-LWN 8.2
KHGI-TV 13.1
KFXL-TV 13.2
NET HD 29.1
NET 2 29.2
NET 3 29.3
energyzer is offline   Reply With Quote
