Old 19-Jul-2012, 4:59 PM   #9
The CM4228HD is a capable UHF only antenna that is a bit more directional than the CS2. You would still be missing out on several high-VHF signals.
I would start by trying new mounting locations... Why replace a good antenna if you don't need to?
The CS reflector kit lists for $19.99. It will improve your high-VHF capability. But, again, experimenting with mounting locations seems the most appropriate 1st step.
