How is the A/D CS2 for this application? How does it compare with the Winegard HD-1080?
Select the VHF-capable version of the C2, not the "regular" C2 that is available at retail stores or at Amazon (and the like) unless you make plans to add the VHF upgrade separately.
Paper comparisons may be made by consulting the respective data sheets:
www.winegard.com/kbase/upload/HD-1080.pdf vs. http://www.antennasdirect.com/cmss_f...%2BVHF-TDS.pdf
