DTV/cell phone reception advise and products
If you want the Canadian stations at 183 degrees and some of the US stations at 166 degrees magnetic, you need to mount a Winegard HD7084P antenna and a Channel Master 7778 amplifier above the roof. Your satellite pole will not work with this large all channel antenna.
Use any mount that will support the antenna above your roof aim the antenna to 166 degrees magnetic. Choose a spot that is clear of large trees or any other obstructions. You can shop for mounts where ever you purchase the antenna.
If you need simple and only want the Canadian channels, you can use the satellite mount, (provided it is located where there is a South view) to mount an RCA ANT751 antenna with no amplifier.
