Old 19-Jul-2012, 2:47 AM   #3
Tv Reception.
A http://antennasdirect.com/store/Clea...VHF-Combo.html , in the attic aimed at about 220 degree magnetic compass.
Will most likely receive the Tv stations/channels in the Green and Yellow reception zones down to WOTH-LD.
If you will like to receive Many More broadcast Tv stations/channels then mount the CS2 Complete UHF/VHF antenna above the roof of the house in such a manner that the antenna is Up High.
Remove the Reflector Screen from the CS2 Complete antenna and aim either side of the antenna at about 13 degree magnetic compass.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.amazon.com.
Antennas receive the best when there is nothing in the way of reception , reducing or blocking reception.
Trees and tree leaves do a good job of reducing and blocking reception.
Buildings in the way of reception will reduce or block reception.
It is a good idea to locate a antenna at a location that has the least amount of stuff in the way.
