Old 18-Jul-2012, 11:58 PM   #1
turrmoil
PLEASE HELP!! With Selection of PreAmp - TV Signal Booster - Is CM7777 a good choice?
Dear all,
I am a newbie to the OTA world.
I have a ClearStream 2 50 mile antenna... details below:
Antenna Specs
The antenna is installed on a mast left behind by Dish Network which is about 5.5 to 6.0 ft from the ground.
Below are the results from TV fool as well:
http://www.tvfool.com/?option=com_wr...9900d85611c7c1
I get channels like GPB Knowledge or GPB Kids which keep cutting in and out.
Based on some reading I was hoping to place a signal preamplifier right close to the antenna mounted outside and hope that these other stations will begin to be received.
I added the GE signal amplifier inside in my distribution box and it seemed to help a little, not a whole lot... I started getting the channels listed above... earlier I was not getting these at all.
Link to GE Signal Amplifier
Thanks all in advance for your help.
Will the CM7777 be a good addition in my case?
If not, what pre-amplifier will be best suited for me.
The GE manual says its boosting signal strength by 4DB or so.
Thanks again for the help and suggestions.
turrmoil is offline   Reply With Quote
