Do you have a volt-ohm meter, or one to borrow?
If you unplug the antenna power supply, do you loose reception on both TVs?
Can you swap TVs... does one TV have a better tuner than the other?
Can you move the power supply upstairs, and swap the splitter ports?
Reason: more questions
