Ahhhh... I'm with you now.
You can try that. One aimed at 002° and the other at 074°. Using a reversed splitter may or may not work. The splitter is cheap and readily available.
If you have trouble with multipath or interaction between the two antennas, you would still have the option to contact tinlee.com who may be able to supply you with a passive tuned antenna combiner. Their AC-7 product comes to mind.
