A second CS600 would not be my choice. The CS600 is designed to receive real channels 2 through 13. It's has no intentional ability to receive UHF.
If you're going to keep the CM3023, try 'hunting' for a 'sweet spot' at various locations, high and low. The design of the CM3023 makes it a capable antenna when you're seeking real channels 14 and higher.
UHF can be interesting, moving an antenna up or down less than a foot can make significant changes in reception.
