Old 18-Jul-2012, 7:05 PM   #1
medic7603
MS 2000 Antenna multiple tv issues
So, I've got this antenna(which I know I need to get back up and get higher in the air, but want to solve other problems first) on my roof. Have a cable from the antenna(which has a built in pre amp apparently) to this splitter
http://www.amazon.com/DIRECTV-SPLIT2...ter+power+pass
That splits it to my upstairs tv and my downstairs tv. the downstairs tv gets all the affiliates, and the CBS is only partially coming in at this time(I'm pretty sure it's due to height, just have to get more pipe to raise the antenna). The upstairs tv only gets the local FOX affiliate.
Here's my TV Fool Report
http://www.tvfool.com/?option=com_wr...9900f06c3b0238
I have the power injector for this antenna connected to the downstairs tv. The only things I've thought of are either the coax upstairs is bad(doubtful as it works fine with other antenna I have that's an indoor antenna). Or maybe it's because the power injector is ultimately connected through the downstairs setup(but allegedly it goes to power the antenna and not back through the antenna as the power pass only goes one way(up to the antenna). I also had a different splitter that had power pass both ways and that didn't work either.
Any help would be greatly appreciated.
medic7603 is offline   Reply With Quote
