If you can mount the antenna a little higher that is likely to help. Don't recommend a pre amp here because the VHF signals are quite strong. The only other option is to use a rotor or setup a 2nd CS 600 and point it in another direction and the combine it with the existing antenna to run a single cable to the TV.
