The aerial view of the address suggests this is a group of several buildings, facing various directions.
A one size fits all solution will work well for some who are able to locate the antenna with a clear view to the south. But for those who can't do so, results will be disappointing.
Having offed that caveat, an antenna that tends to fit your request is the RCA ANT-751.
I realize the following tends to contradict your stated request. If I were building new at this location, I would install a roof mounted combination on each building consisting of an Antennas Direct DB4e, Antennacraft Y5713 and a Distribution amplifier (the make and model TBD based on the number of units / TVs to be fed). This would put a single antenna mast on each building, offering consistent results to each viewer.
Reason: grammar, clarification
