Ok. So I got home tonight and the splitter was here. Hooked it up outside and came back in, rescanned and have fewer channels than I did with the mohu I had in my window, but not by much. This is considerably less than I get with the TV downstairs also connected to the winegard rooftop antenna. Why do I get such incredibly different channels on two different tvs? Could it be the coax going into my wall is just bad? Or could it be because the power injector powering the preamp in the antenna is connected to the coax downstairs and the upstairs suffers as a result? And yes, I made sure the downstairs(powered) coax is connected to the power through side of the splitter. Thoughts? If it's the coax I can look at that tomorrow I guess.
