Tv Reception.
GUM says.
True , but .
So many weak signals.
teleview says.
Well lets see.
WTNH 47.2 NM (dB) , ABC
WCCT 35.5 NM (dB) , CW
WTIC 35.3 NM (dB) , FOX
WEDY 34.8 NM (dB) , PBS
WFSB 34.4 NM (dB) , CBS
WVIT 31.1 NM (dB) , NBC
WCTX 33.0 NM (dB) , MYNetwork
WEDH 31.9 NM (dB) , PBS
WUVN 25.6 NM (dB) , Univision
The above are all strong signal strength. Plenty of signal strength elbow room for reception.
And now weaker signal strength.
WFTY 12.6 NM (dB) Telefutura
WWLP 10.4 NM (dB) NBC
And Now the Weak signal strength.
WHPX 8.1 NM (dB)
It is true that , WFTY , WWLP , WHPX are weaker and weak.
Even if the CS2 Complete has 0 gain with the reflector screen removed.
That still leaves signal strengths of , 12.6 NM (dB) , 10.4 NM (dB) and 8.1 NM (dB) , and a preamp gain of 17 to push the signals out to the Tv's.
And if the CS2 Complete has a gain of 5 with the reflector screen removed then thats ,
WFTY 17.6 NM (dB)
WWLP 15.4 NM (dB)
WHXP 13.1 NM (dB)
plus the 17 dB preamp to push the signals out to the Tv's.
If all this comes down to,
WHPX ION as the problem Tv station then I have dealt with that issue.
I stand by my recommendation for reception.
