Old 18-Jul-2012, 3:19 AM   #14
Tv Reception.
For reception with the CS2 Complete , no mater if ION is received or not , use only the CPA-19 preamp.
For 1 Tv connection use no splitter.
For 2 Tv connections use a , http://www.hollandelectronics.com , also avaliable at http://www.solidsignal.com.
HFS-2D , 2 way splitter.
HFS-3D , 3 way splitter for 3 Tv's connected.
If it comes to using the HD9095P antenna to receive WHPX ION at 122 degree magnetic compass.
The HD9095P antenna will be be a separate antenna system and will not be connected to the CS2 Complete antenna system.
Reception of WHPX ION with the HD9095P antenna should not require a amplifier for reception on . 1 , 2 or 3 TV's.
HFS-2D for 2 Tv's connected.
HFS-3D for 3 Tv's connected.
The CS2 Complete antenna system and the HD9095P antenna system are 2 separate antenna systems that are not connected to geather on to one coax system.
The 2 separate antenna systems coaxes will go to each Tv location and a Remote Control A/B antenna switch at each location will change antennas.
http://www.radioshack.com , # 15-1968 , or , http://mcmelectronics.com, # 32-4425.
