Go with the Antennacraft Y10-7-13 instead of the Winegard Y1713. I set up both on the same mast at the same spot and the Antennacraft was able to get a lock on a very weak Ch. 7 while the Winegard could not. Someone actually modeled these antennas on another board and his spectrum analyzer photos showed the Antennacraft antenna has a solid 2 db higher gain across the entire VHF hi spectrum. Bottom line. If you need more gain then go with the Antennacraft antenna.
