Some, not all, power lines are problematic noise sources for real channels 2 through 6 in particular. Channels 7 through 13 are going to be affected less. The UHF channels will be impacted the least. If that location is the only choice you have... give it a try. If you have alternatives, great.
On a safety note: Stay far enough away from power lines so that if the antenna and mast fell they could not come in contact with the power lines.
