Tv Reception.
If the antenna is aimed at WHPX at 122 degree magnetic compass , WHPX will be received and the north north east group will be received , however that will put the south west group on the side of the antenna and most of the south group will not be received.
WHPX is the Odd one out because of the location.
If the 170 aim direction does not get the north north east group and south west group and WHPX.
Then I recommend aim the antenna at 200 degree magnetic compass.
And if you will like to receive WHPX ION then install a separate antenna , a Winegard HD9095P antenna aimed at 122 degree magnetic compass.
The coax of the HD9095P antenna is separate and will not be connected to the coax of the CS2 Complete or any part of the CS2 Complete antenna system.
