Tv Reception.
NO antenna rotator is required.
The CS2 Complete is designed the Tv channels , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Your location has receivable Tv channels in the , VHF high band 7 thru 13 and UHF band 14 thru 51.
The CS2 Complete with the reflector Screen removed will receive in both directions at the same time.
So only one coax from the antenna.
The Tv's Must channel scan for the Broadcast Tv Channels sometimes named the "Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO NOT scan for cable tv channels.
