Generally an antenna mounted outside in the clear is able to perform far better than the same antenna inside a building. But often an indoor antenna can make do.
You may want to consider using an antenna designed for outdoor installation.
The Antennas direct SR15 and Channel Master CM3022 come to mind. Both are just under 3' long and may find a happy home on top of a book case pointing south and a bit west.
This would not give you every available signal... to accomplish that would call for outdoor mounting and different antenna choice(s).
http://www.antennasdirect.com/store/...V_Antenna.html
http://www.channelmaster.com/Masterp...3022_s/298.htm
Reason: added links
