Old 17-Jul-2012, 6:59 PM   #11
Receiving Tv stations.
The Colorado and Wyoming stations will be received. NO antenna rotor required.
Above The Roof.
Install a Antennas Direct C5 antenna aimed at 150 degree magnetic compass reading. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
As always , the starting aim direction is the -> starting aim direction. The antenna is then turned to find the direction that receives the receivable Tv stations the best.
For your location the starting aim direction is about 150 degree magnetic compass , the antenna is then turned toward the south and south west for the best reception of the receivable Tv stations/channels.
The Digital Tv Stations Channels in the Current Plus Pending Applications Included Channel List.
Tvfool shows the Real And Actual channels that are being transmitted and received.
And tvfool also shows the Virtual channel numbers.
The REAL Tv Channels in the tvfool channel list will be received down to KCNC-DT Real channel UHF 35 Virtual channel (4.1) , will be received.
Here are above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to by antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.amazon.com.
For 3 Tv's connected install a Channel Master CM3414 distribution amplifier.
The C5 antenna Must be mounted up high above the roof in such a manner that the roof of the house is not restricting or reducing the reception of the C5 antenna in any direction.
Also it is a good idea to mount a Tv antenna so that there is the least amount of obstacles in the way of reception such as trees and tree leaves and other buildings.
The C5 antenna receives channels , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Your receivable channels in the tvfool Green and Yellow zones are in the VHF high band 7 thru 13 and UHF band 14 thru 51.
The Federal Antenna Law says Yes you can , Install , Use , Maintain , antennas on your property.
http://www.fcc.gov/guides/over-air-r...n-devices-rule
Hoa's can not delay or prevent you from installing antennas.
And no , you can not be required or even suggested that have to hide the antennas.
Hoa's and housing covennuts and etc. , are 100% aware of this Federal Antenna Law yet still seek to scam people.
