GUM,
Thanks for the reply. Unfortunately, the HOA does not allow me to mount outside. I could also mount in the attic, which gets me up around 25' or so.
As for the splitter, I was intending to use the whole house splitter that is in the garage. I believe this has ~8 or so splits on it. I'm assuming it's okay to use this one. Would the stubs from the cables not in use hurt the signal?
Are you suggesting the preamp since I'm feeding multiple tv's or in general since I'm a good distance from all broadcasting towers?
Thanks for the links as well. Seems like a rotator may be a large source of frustration and at least initially I'm better off just focusing on Denver.
