I took your advice and went directly to the main television. So far FOX and PBS from 41 miles (303 degrees) is coming in stronger but just recently it went out for about 20 minutes. Regarding the other channels I do not pull the stations from the North in b/c I do not have a rotor to turn the antenns. I failed to mention a large maple 75 feet away from antenna that is partially blocking that direction.
