Old 16-Jul-2012, 12:41 PM   #3
signals unlimited
DTV/cell phone reception reception advise and products
The round antenna on the floor will not work on the floor or in the attic for VHF 10.
VHF 10 is also in a different direction from your main group of stations at around 300 degrees magnetic. If your home has a standard shingle roof, the attic will work if you do the following:
Use an Antennas Direct DB2e Uhf antenna aimed to 300 degrees and an Antennacraft Y5-7-13 High VHF antenna aimed to 19 degrees. You can mount these on one mast about 12" apart. Use a U/V joiner to combind the antennas into one coax. The joiner and the antennas are available at www.solidsignals.com
